Proper way and order for piston ring install?
ByrdClaw
144
Aug 21, 2007
Sacramento, California
I am about to be installing my piston rings,I have 3 questions.
1. Do I need a piston ring expander tool?
2. Do I install them from the bottom of the piston,or top?
3. In what order do I install them? oil ring first then middle to top?
Any input is appreciated.
Yes you need the ring expander. If you try by hand you will likely break the rings. I don't think order matters, but if you just start at the top or the bottom and then go in order up or down. I alway go over the top of the piston and put the bottom ring on first and then go up. There is a lot of info on this do a search.
http://www.dsmtuners.com/forums/newbie-forum/348577-how-install-piston-rings.html
