Proper part order
blanks
52
Mar 24, 2013
Charlottetown, PE, Canada
I made another thread in a different section with no responses, hopefully I get one here,
So I noticed on the ASA when ordering Conn Rod bearings, it has a selection of 3, Plain STD1 through to 3. Im guessing that its for excessive wear on the Crankshaft? Aswell the balance shaft tensioner, there is different ones so assuming its the original block then my part number would be MD192068 94.05.03 - 97.06.03
Same with the adjuster,tensioner for timing belt that goes 95-99
The sticker for the engine id # was still on the block and reads IorTU0610X6, I remember reading somewheres that the 7th letter in that tells you when your block was manufactured.
If anyone can help me out with any input, or if they need a pic of something specific to tell me I have no problem doing so. I just want to be 100% sure I get the right parts ordered in this next big order I make. Thanks.
If you are using your original crank or a used crank you need to get it checked. It may need polished or cut. Have machine shop check it out and they can tell you what size bearings you need.
As far as the asa I can't look up the part number on my phone. But it shouod be easy enough to find if you know what motor you got.
