Proper Oil Lines For a 1G
jmorri15
63
Mar 6, 2009
Kemp, Texas
so i took the turbo out to do some work and i noticed the top oil line is a tiny copper line running from the top left of my engine block and then a large return line to the oil pan. now according to what ive read on a 2g car the feed line will be running from right beside my oil filter. for my 92 gvr4 what should the right setup be. oh and im running a greddy 18g so its slightly larger then stock.
What you have sounds like stock 1g 4g63 setup. The oil feed line into the turbo comes from the left side of the head (like you said) and then the larger return line to the oil pan. Some people relocate their oil feed line to come from the oil filter area (from one of the oil pressure ports) so that they can get higher oil pressure to their turbo (oil pressure in the head area is lower than block/oil filter area). Your setup seems stock so as long as your turbo is okay and there aren't any (many) leaks, you should be good! :rocks:
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
