Proper MBC set-up
4g63telantra
454
Dec 10, 2004
Toronto,
I seen a few set-ups for a MBC.
Just wanted to know if this set-up is good or should I change it around?
EX wastegate--->MBC-->"T" to BOV and other to Intake manifold
4g63telantra said:
So i dont need a vacuum from the turbo? (t3/t4 50trim has a nipple on it)
You can use any pressure source you want to, but it is recommended to run it off of the BOV line for higher boost applications (15+psi) according to Turbo XS.
