- Thread starter
- #26
red_gsx
- 145
- 2
- Aug 18, 2004
Rockville,
Maryland
It's been a while since I posted up on this topic or even logged on to the forums. The reasoning is that work has been insane and my internet just got fixed up this week after being worthless. I've added a couple more pics to the album, link below, of the work me and a buddy of mine did last Sunday. I've decided to take a different approach to the project due to the weather starting to get colder in the temps and the rain being more frequent. My goal is to now finish pulling the bottom end and trans out of the GSX and bring the bottom end inside. Instead of taking chances with the motor on the Spyder I want to take apart and do a basic, no stroking or bigger pistons, etc, rebuild on the GSX block. This way when spring comes around and laying on the ground becomes bearable again I will be able to drop in a block that I know is in good shape. Thanks to all who have expressed interest once again.
So now for an update of what I did last Sunday for anyone interested. As you can see a couple major parts have been pulled out. Head, intake and exhaust manifold, starter and some other accessories. The passenger axle is stuck inside the hub and is being a pain while the driver's is out of the hub and half-shaft is out of the trans. I noticed a nice sized crack in my SBR exhaust manifold but I guess it is to be expected for the amount of time it sat and the rust all over it. Three cheers for cast iron and having welder friends though. My rotors are look like they were just pulled from the Titanic. The powder coated calipers held up great though. Head was nice and clean, pistons had a layer of carbon built up but chambers were free of rust. Transmission was showing rust on some of the bolts but not the body itself. Down pipe bolts were tight but did not snap and the down pipe also had a good amount of rust. Some of the studs came out of the head when I removed the exhaust manifold and I did not even try to separate the turbo and o2 housing from it.
All in all it is to be expected for all I found other than the exhaust manifold crack. I will keep doing updates on this board from time to time as progress is made. Just wanted to let everyone know that the project is not dead by any means. Delayed? Yes. Different direction? Also yes but not dead.
Spyder GSX pictures by artem_tb - Photobucket
The downside is that it has no management systems or interior and could of course, like most 2G's use a little TLC. My guy did all the technical work but he does not dable with the aftermarket aspects. This would be outstanding except for all the aftermarket goodies that throw the Air/Fuel ratio and keep boost all over the place. Plus it has no radio or speakers. The better news is that all these things are in my GSX and both the cars are hanging out in my driveway.
