2G Programming Keyless Entry?
96DSM_Steve
262
5
Aug 19, 2010
Bakersfield, California
Dude get them from Mitsubishiparts.com they are like $60 I think. I got one two years ago for $40 from them and you can sync it to car yourself takes like 5 min.
Here's a post I take about it more in. http://www.dsmtuners.com/forums/maintenance-repairs/423252-alarm-i-didnt-know-i-had.html
How to sync remote key fob to car:
1. Locate the Data Port.
2. Insert keys in ignition and leave in the OFF position.
3. Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port with a suitable jumper wire, leave jumper wire connected throughout the programming procedure. Make sure you know which terminals are 1 and 4.
4. Within 10 seconds after connecting the jumper wire, turn the ignition switch to the ACC position and then back to OFF. #Note: The doors will automatically lock and unlock once at this time indicating that the system is in the programming mode.
5. Press the LOCK# button on the transmitter to be registered three times within 10 seconds.# Upon successful programming, the door will lock and unlock once.
6. If there are two remotes, register the first, then register the second. Repeat step 5 within one minute to program second remote. After completing the second programming, the doors will lock and unlock once.
7. Disconnect the programming wire and remove the keys from the ignition.
