Profec Bezel
bjw24
61
Mar 14, 2007
Bradford, Pennsylvania
Does anyone know if they sell a 2g bezel that is for a profec, turbo timer, and cd player? Or even just the Profec really I want to mount it under my cd player and need it to look clean.
Well thanks for that one the guy said he could have made one awhile ago however he has lost his resources to make them anymore :(. Anyone else know where I could get a bezel for a 2g? I see slowboy has a ton of the cd player ones for 1g.
You can make your own. Thats what I did, it turned out alright.
I created my own as well much like the one that Chuck_3 posted.
To do so, I purchased a standard dash kit for a 2g from my local best buy for around $10-$15. I then measured and cut the lower half to match my boost controller. You must do so carefully in order to ensure proper fitment.
That's really nice. What did you use to make it (and how was it made)?
Thanks. I bought the dash kit from a local audio store and just used a piece of the greddy profec box and cut it to fit the open slot under the cd player. Then measured and cut the slots for the TT and EBC and put some resin on the cardboard for extra strength, sanded it down and painted it.
Last time this was brought up.... He explained that he just installed it wrong since he wasn't thinking and then after it lit up he noticed it was upside down.
Would you put the SAFC2 in the ac vents or in the cd player area?
I have a boost gauge I want to install but am still thinking should I go single pod a pillar, ac vent area, or what?
The a pillar is giving my sleeper look away. I really don't like the cluster gauge pods but besides the vent and cd player that's all I can think of.
If you want to go for the sleeper look like I am, (I hate a pillar pods). I cut out my cigarette lighter with a dremel and put it there. My next set of guages will replace the ashtray and couple holder.
I think I found another spot for the boost gauge. Thanks for that cig. lighter idea but I'd hate to look down when I measure my boost readings.
What I'm thinking is since I took out my fogs I can take that little panel that has the mirror adjusting buttons on it and the fog light switch. It's a perfect fit for a 52mm gauge. I can leave it in there but only thing I don't like is the missing piece below the gauge, so I'm trying to sketch out a custom panel to replace it and hold the boost gauge as well. Pics to come.
