Dieselboy
- 2,359
- 1
- Nov 6, 2002
Seattle Area,
Washington
This is the product under review for those who are unfamiliar with is:
http://www.homemadesimple.com/mrcleanautodry/
Most of us (espesially those of us with dark paint) are getting sick of water spots after washing our cars. I dont know about you, but I hate the choir of having to wipe down my car after washing to eliminate MOST of the spots. Mr. Clean AutoDry has been around for a little while now, but I never took the time to give it a try (wish I did now). For those who havent heard of it or tried it, this is how it works.
- You are supplied with a gun that screws to your garden hose. In that gun is a small tank for the specially formulated AutoDry soap (small bottle supplied), and a chamber for the AutoDry water filter (one is supplied, lasts up to 10 washes). Both the soap and the filter refills are available at any automotive store.
- The gun has 3 settings on it, one for water straight from the hose, one for the soap concetrate, and the last for the water to flow through the AutoDry filter.
- You begin with an overall basic rinse off of the straight hose water as you normally would. Afterward, you switch to the soap setting and spray a section (you want to spray only a section at a time). Follow that up with a quick scrub with a towel or mit and rinse the section off with the normal rinse.
- Follow through until the whole car is washed. Afterwards, switch the gun to the filtered spray and start at the top. Watch the filtered water basiclaly push off the normal tap water.
The results after drying, a crystal clear shine with no water spots what so ever. Even in 70F sunny weather, the car still dried with no spots (and I have a dark maroon paint w/ black top). Bottom line, this stuff really works.
i actually ran out so i have used dish soap
actually looks good... just dont use alot if you use dish soap...
wow
The absorber is great, but the blade...
