problems with new motor
bmason
73
Feb 26, 2006
mchenry, Illinois
so i got the new engine and i was transfering all my stuff and i notice alot of differnces in the 2 motors
1. the 2 cam gears are wrong 1 is right but the other doesnt have the timing sheild
2.the slingers isnt there and i had to transfer it from other engine
3 the other oil slinger on the engine that is there the gear is sheared
here is some pictures i took that i am going to send to them, i think they might have sent me the non turbo engine does anyone have pics of a non turbo engine torn apart vs a turbo engine torn apart
this is a side view of the gear that was sheared were u can see the burn marks and some chips
there is top view of it
gears they sent me
gears i needed
does anyone know why they did this before i call them and want some of my money back
That looks kinda crappy. Is this a new, rebuilt, or just a used engine? I thought they sell rebuilt/remanufactured. In which case it could be damage from shipping?
Call tha sonsa'GUns on the phone and get it straigtned out.
What kind of deal did you get from them? I think they advertise here.
First off, answer whether it's a 6-bolt. Second, are you calling the balance shafts "slingers"??? If they're not there, that's good. I think Karking eliminates balance shafts. But hey, be glad you didn't end up like me and ordering a motor and having it arrive to find the balance shaft belt had snapped, caused the motor to jump timing and smashed all the intake valves. This was before I installed it by the way.
Like Keymaster points out, the first part is the oil pump gear and stub of what was the balance shaft. It's been cut down and the oil passage welded shut. You'll want to pull out the other balance shaft if you put it in the block and make sure you didn't remove the plug on the front cover.
You got the cam gears from a 1G. Again the other guys have pointed out that you should be checking to see if your putting in a 6 bolt engine. If you are you 'll have other issues to address like the mounts.
Steve
yeah i called them and they were like
" we dont put the balance shafts in and we dont have the cam gears in stock so we just send a not saying u need to switch them"
and i was like ghey
This is a technical forum. You have been given warnings about using proper grammer and you have ignored them.
If you express yourself to the the vendor the way you do here, you won't be taken seriously.
sorry i am just a little aggervated latly becuas i have been out of a car for so long now
Well, don't take it out on those of us trying to help you. Really doesn't make people very motivated to respond to you.
Ok, so what's the question? The balance shafts are already eliminated for you, which saves some work. And those cam gears will work just fine. What's the problem?
edit: Find your damn shift key!
bmason said:
it is a 7 bolt
I'm just trying to be helpful here. You need to use proper grammer, spelling, and punctuation, or you are going to get banned. Take some time and use a dictionary if you have to. Don't be lazy.
