Problems starting up the car
doodie
1,025
Aug 11, 2002
Brooklyn, New York
I just recently put in 550cc injecotors in my car and a Keydiver chip to run the 550's. I have my SAFC set at -10% across the board for the high settings. On the first few days, the car started up fine and for a few times, it cranks right on in less than a second.
Now, when the engine is cold, it takes a while to crank the car on. And when it finally turns over, it stumbles to stay on and takes a few seconds to idle like normal. Does it sound like I have a leak somewhere? It almost seems like I'm not getting enough fuel pressure or something. The car runs great and better than ever but its just the start up thats getting bad.
interesting thing happened just before. I plugged in the pocketlogger and it showed the Short-terrm Fuel trim to be around -5% to -6% and the car was idling like total dookie. I used the SAFC and leaned out the LO-Settings to -3% and the pocketlogger showed that its 0'd out.
Am I having such a hard time starting up the car because its dumping so much fuel in on ignition that its blowing out the spark?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
