Problem with Slave cylinder rebuild
tarheels23
101
May 15, 2011
struthers, Ohio
So the ass as advanced auto parts gave me the wrong rebuild kit and the bore was too big, so i took the rubber seal off of the new one and put it on my old one and now when I try to bleed the clutch I can push the cylinder in but wont come back out because the seal is tight! so any ideas what I can do?
The cylinder won't come back out on it's own. It has to have some pressure behind it. Every slave I've messed with would stay in until someone stepped on the pedal.
Are you saying that when you step on the clutch pedal it won't extend?
