Problem starting car.
ncoop2323
Mar 14, 2009
Oxfode, Michigan
My buddies 92 awd TSI won't start. He told me that only two injectors are working and wanted me to post up here to see if anyone knows what might be the problem or where to start in looking to fix it.
Only two of them are clicking when he turns the key on and the check engine light blinks when he turns the key on.
Clicking when the key is in the "ON" position but engine not started, or with the engine cranking? From my experience so far, the pump/relay only works while cranking/started and the CEL stays on with the key on, engine off. You should check power/ground to those injectors while cranking. Get a ecu pinout and make sure the injector pins are pushed into the harness plug all the way, and not severed.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
