Problem Revving up
dherron
87
4
Jun 12, 2004
Uhrichsville, Ohio
Just got a 1990 Talon Tsi Awd yesterday and I need help. Since i have been working on them for a while i figured it would be a easy fix but was i wrong. The car will start fine now but it still has trouble revving up and it misses while doing so. You can rule out clogged exhaust. Any other ideas as to what it could be. MAS?
talonTSIDriver said:
Also not sure if you tried the simple plugs and wires. stuttering is a sign of poor ignition. But also check for boost leaks right away.
Agreed. Also, if the plugs are new make sure they are gaped correctly to .028. Also, when you do the boost leak test use soap and water, it makes leaks more visible. :thumb:
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
