Revving problem
02BLUR
274
3
Feb 6, 2003
Bothell, Washington
When I rev up to about 6k, mostly in 3rd or 4th gear, it feels like the power really flattens out and it sputters slightly, almost like a streetbike hitting the rev limiter. Then just for a second, three dash lights flicker on : water, brake and another uknown (right in the center)
I just replaced the caps in my ECU, and from what I have read, those caps regulate the voltage in the alternator, I think I may have not done a very good job on the cap replacement.
It seems to be with prolonged (5 seconds) acceleration, as the output of the alternator falls, because for short bursts, it does not do it. But maybe I need a new alternator, also...cause that thing is getting old.
:confused:
What do you think?
I have a big 16g, boost controller turned up to about 15psi, 255 fuel pump.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
