Problem after problem HELP please
92_talonGsXt
117
Jan 1, 2009
lake forest, California
My 1g is still having problems after my no spark incident, now I have spark, fuel,brand new starter/battery,alternator,good ecu,timing is on point,checked all my fuses,cranks over but doesent want to turn on, what can it be, coolant temp sensor,MPI relay etc??? Please help
Can you tell if the injectors are clicking ? if you can't, try hooking up a cas to the harness. turn the key on and spin the driver a half a turn by hand . you should be able to hear the injector clicking on and off. i always spin it a couple of times to listen for them to fire
Can you tell us what you know that you have taking place? Engines need spark, fuel, and combustion. Can you tell if you're getting spark at the right time? Can you tell if you're getting fuel at the right time? And is the engine building pressure and vacuum?
Yeah CAS could be 180* out (did you have it off at all)? Firing order correct? You have compression?
My CAS went bad and caused a no spark & replaced with another cas and now I have spark on all 4 cylinders,how do I reset the CAS back to normal 5 degrees,my firing order is on point, I also have compression
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
