Starting problem after uego install, please help
thewraith
395
Aug 28, 2007
Washington,
Hi all,
After installing the AEM UEGO and wiring it to the rear o2 sensor wire, I have the following problem:
The car will start, and the rpm's are at about 2.5k for a few seconds. Then the car just dies on me. I may have mixed the wires that go from the harness back to the sensors up since I had cut both. Or is there a setting in dsmlink that I have to adjust to fix this? Please advise!
thanks
meek
Maybe I wasn't clear enough with my question. The bung has been welded on properly to the dp. I am now trying to log with the aem wb to the dsmlink. To do so- I had to splice into the ECU, one of my options was to splice into the wire for the rear o2 sensor. After splicing I am having this issue. Any help would be appreciated.
