Problem, Help Please!
AlmightySo
285
20
May 1, 2014
New Castle, Delaware
My car drives fine once im going at a good speed but once I get to a stop light and try to go, its slow like its in neutral.. What needs to be done or whats the problem? Its pretty hot under the hood and im at this party right now.. I dont want to be stuck here!
That could be a whole cluster#### of issues.. Could be blown headgasket, could be a massive boost or vacuum leak, could be anything really.. Just limp it home and then trouble shoot.
Manual or Auto? Check ALL your fluids before you drive it again. If it overheats, roll windows down and turn on heater... it sucks heat from engine helping cool. I was flying 140+ in a previous Supra for 100 miles and using heater was only way to keep temp down. Hehe. Good fun. Good luck
Its manuel, & yea I turned heat on all the way on the drive home, I only have 1 rad fan so I stopped in autozone an picked up another one. The rad fuses are blown or bad wiring ? Cause I had to run the fan straight to the battery.
