Pressure Plate to Flywheel Bolts Question
mnetwork
1,017
Feb 25, 2006
New Milford, New Jersey
Some vendors sell the Auto bolts as they are a little longer than the 5spd ones. That may be the difference in the two, both oem.
The Auto wouldnt have Pressure plate to flywheel bolts. Im confused on what bolts you are thinking of.
OP: The Part number you got may have been superseded by the part number they have. When I get home, I will get on caps and try to figure it out, if you don't have an answer by then
Were you ever able to find this?
Is it safe to reuse these bolts? I replaced my flywheel bolts with brand new ones but wasn't sure about these.
I just wound up cancelling the order I put in for the other bolts and ordered the ones Extreme PSI stocked. Motor/trans in. Just have to hook everything else up...
I just checked in CAPS. The proper number for a 2g FWD pressure plate bolt is MF241251.
Those are the ones I ordered. I always thought that the tourqe spec for those seemed very low. I tourqued it down to 16 with blue loctite. Should be fine right?
Yeah
o_o Heck.. when i did mine.. I just went and grabbed grade 8 Bolts of the correct thread and used blue loctite. Not a bit of trouble.
Did the same thing on my N/T and drove it for over 5K without issues before I sold it.
