Pre installation of T25 need help
Fabian972
264
Oct 18, 2005
Garland, Texas
I am a few weeks away from installing my big28 my first turbo install i want to make sure everything goes smooth. Now i have check FAQ form and tech guide but i have not got all the info i need i am looking for torque spec. For a 97 Gs-T
  1. Exhaust man to turbo I have been told 20 to 24ft lbs ( correct me if I am wrong)
  2. O2 housing to turbo ???ft lbs
  3. Oil drain tube to turbo ???ft lbs
  4. Oil feed line to turbo ??ft lbs
Help me fill in the blanks also any other spec that I might need are welcome.
I can post them when I get home, however, I would suggest that you go buy a Hanes or Chilton manual.
They are handy, cheap, and have all the torque specs.
How is this?:thumb: :talon:
Yeah I have the Chilton but I have been told it conflicts with the Factory manual info..just want to be as acurate as possible.
That picture came directly from an International Automotive Repair Reference websited available to students at the college I attend. It is year and model specific and is the same sheet I followed. Its accurate.
Don't want to sound picky that's for the 2nd gen right it looks like it just want to be sure If it is that's sexy. Also is it factory manual spec or other spec ? Thanks agian that rocks
Here are the torque specs for the exhaust manifold to turbo bolts and the O2 housing to downpipe bolts as well. Along with others you might find useful.
If you have any questions with the swap, let me know as I just did it myself and it is fresh in my mind.
Reference this thread for part numbers. (half way down the page posted by me.)
Good luck.:cool:
