PR Rad. Slim Fan wiring
danielsl1999gsx
847
93
Jun 5, 2009
los angles, California
OK so ive done some research on how to wire these fans to my OE wires and this is what i got so far.
Rad Fan Wires
*White/Black & White/Blue-connected to blue Wire
*Black & Blue/green-connected to Black Wire
A/C FAN
*Blue & Blue/White-Connected to Blue Wire
*Black & Blue/Black - Connected to Black Wire
Now my question is my car does not have A/C anymore so that means my A/C fan will never turn on since i never run A/C. What would be the best way to make both of my fans turn run like the Rad. Fan hooking them both up to one plug? Im not a wire genius so i have no idea how to run relays and what not. So if theres not simple way to run it should i just leave it off and keep it for back up?
well I have a 420a, and don't have my service manual right infront of me. but in my service manual, it states which temps which fans come on. if A/C is turned on, the A/C fan automatically comes on, but i dont remember the temperature, but closer to extreme temps, the A/C fan still comes on. I'll grab my manual here in a second, but you could wire the A/C fan into the other fan so they would both run with the temp settings of the cooling fan. or could always remote switch them so they either run off a switch or are just always on. but i would reccommend just wiring them into the other fan.
EDIT
so my scanner is being ### so i had to use my cell but here's the cooling sensors for the fans. my fans dont have speed settings since i put in high speed fans. they are either on or off.
Ah sweet thanks this helps so i guess im just gona wire them both into the Radiator Fan, so they both come on at that same Temp. So now my question would be i connect both Blue & Black on the Slim Fans then wire then to the Rad Fan plug Correct?
um. i'll get back to ya in the morning when i see how i wired mine...i remember there are 3 wires. one being for the low speed, one for high speed and ground. i just tested my wires and then soldered the 2 speed ones together.
and it isn't required to wire the 2 together. even with not using the A/C, both fans will still work. the A/C fan is more of a backup in that case incase your coolant fan can't keep up.
