AC Slim fan wiring
TSITurbo95
18
Oct 26, 2009
Ohio, Ohio
Ok, so I tried searching, but came up with no clear results. My AC fan is done for (bearing went bad), and have a slim fan lying around. It has 2 wires, black and blue. I would like to cut the harness off the old ac fan and wire it to the new one. What wires would I need to connect to the blue and black for it to be on high speed when AC kicks on?
I saw that, and personally I do not understand that wiring diagram, anyway to simpleize it? And haha I wont.
To simplify: Connect the two OE positive wires to the new fan positive, and connect the two OE negative wires to the new fan negative.
This will have the new single speed fan running when the OE controls call for either speed.
So doing this doesnt burn a fuse or over heat the relay? If you wire the two fans together like that doesnt the one fuse/relay control both?
Not two fans wired together.
The OE fan is a two speed fan. The Slimline is a single speed fan.
The new Slimline fan should run when either speed of the OE fan is called for.
The wiring in the referenced diagram just turns on the Slimline when the OE fan would have been on in either speed.
Work fine on my Talon. Your mileage may vary.
