PR fmic and power steering
Daniel Brandt
Dec 19, 2015
Woodbury, Minnesota
Do you need to delete your power steering for this kit to work has anyone ran the piping through a different location that the two d holes?
alright cool. How do you fit the piping through the d hole that has the power steering lines running through it on the drivers side
Alright got it mounted now just wondering if any of you have had to order longer couplers than that came with the kit mine don't reach through the d holes and the dh holes aren't wide enough for the piping to fit through or are ppl just cutting the holes larger? Also what is the canister on the passenger side in front of the core does it have a purpose if I'm not running ac I know I took one ac line off of it but not sure what the other line going to the top of it is
You need to cut the holes larger, be real careful of the wiring harness on the passenger side. Dont rush it or you will have to be doing wiring repairs. The link that I posted has some good pictures of the holes enlarged.
