Resolved Power Steering Pump - Nut Size Question - URGENT
Dr Funkenstein
322
Aug 5, 2010
Bangfield, Massachusetts
Not getting any responses in my other thread. I've been looking online and at the stores for literally hours today for ONE SINGLE NUT that I need and can't find anything. I'm confused, angry and about to have a panic attack.
WHAT SIZE AND SPECS DO I NEED FOR THE NUT THAT GOES HERE!?
Tried and didn't fit: M10 x 1.50 and M12 x 1.75
Help, please!:cry::cry::cry::cry::cry:
M12 x 1.25, torque it to 14-21 Nm or 10-15 ft.lbs. There is a M12 spring washer that goes there as well.
Solution
Can you explain the second part of nut sizing. I get that M10 = 17mm and M12 = 18mm, but I thought the other number was the size of the inner diameter or something. The 1.50 was way way too small and the 1.75 was a little too small, so wouldn't the 1.25 be even smaller?
The first number is the bolt, or in this case the bolt hole, nominal diameter. That means the stud/bolt on the power steering pump is a 12mm diameter (nominal). The second number is the thread pitch or the distance along the shank between one position on a thread to the same position on an adjacent thread. For the number I gave, it is 1.25mm pitch.
I am figuring, since you tried the 1.75 thread, that it must be the 1.25 thread. It is most definitely a M12 nut and those are the only two pitches used on these cars for a M12 bolt/nut. But yes a 1.25 pitch would be closer together (smaller, if you'd like) than a 1.75 pitch.
God damn, I'm retarded! Thank you very much, I was stressing out all day!:banghead:
