Power steering nipple
Maxter22
Oct 19, 2010
Blaine, Minnesota
What's the purpose of the nipple on the power steering? Also I've been having trouble with my alternator. Another thing too is my battery keeps getting hot after driving. I've also been shorting my headlights out. But when its on high beam its ok and doesn't burn out. My gauge cluster is also very bright. Any ideas anyone?
still confused
Thanks for the advice. I guess I'll be putting to use the lifetime warranty from Autozone.
Has the car ever had an alarm installed or had the wiring out of it? Something seems really off here. You should check the voltages going to the headlights with a volt meter as they should not be "shorting out"
Its most likely the voltage regulator dumping high voltage through you battery and lights causing lights to blow and your batter to overcharge hence getting very hot replace your ALT and you'll be good to go
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
