Power Outlet ?
99gsx0221
81
Feb 17, 2006
Grand Haven, Michigan
Okay, so my power outlet inside my car doesn't seem to have any power running to it. I try to plug my battery charger in, and nothing happens. Could this be a simple fuse? Or another problem? If it is a fuse, does anyone know what it would be called or located?
Does it light up when you turn your lights on? It is very simple and just has 2 wires going to it. A 12V off the ignition and a ground along with an illum. wire. Check to make sure the wires are connected. Not sure which fuse it goes off of but I would check them all.
Check your kick panel fuses (I assume that's where they are in a 2G). It will probably say something like cig/radio. It might be on it's own or with something other than the radio, but you get the idea. Just pop it out and look.
yeah it could easily be a fuse but mine didnt work either and i removed the center console to find some idiot before me cut the wires.WTF Im going to just fund a good power source and hook it back up!
make sure the battery charger fuse are not blown. Sometimes those charger have their own fuse and they can blow out.
