Power Accessories Door Swap
tr0n
Jul 31, 2009
STL, Missouri
I've searched the hell out of this site and another for the past hour and I only find vague references to door swaps for this upgrade.
I have a 1G Eclipse and I am in need of a door swap. I currently have manual windows/locks and I'm thinking about grabbing a powered accessory door from the junkyard. I understand that the wiring harness is the same so there shouldn't be a problem with this other than pulling the wiring through to where it needs to be plugged in - under the dash somewhere?
Does anyone have any information on this or can point me to a thread that gives a step by step or at least some more information? Can I do a door swap and be done? Do I need both doors to be powered for them to work properly or can I just do one for now and the other later?
Thanks
Im not sure what you were searching on here but there is a MERGED thread on this topic with everything in it you'd need. I pulled the info from one of the posts on there of someone who did a small write-up of the swap and edited it a bit so its an easier read. Power Window and Power Door Lock Installation [Merged 3-7]
  1. Look under the dash (pull down the kick guard) and there should be two plugs up there. One is WHITE (which should be plugged into the harness for power mirrors) and the other is GRAY (power windows and locks).
  2. I went to the 1990 (the one WITH power windows) took out the motor/lift assembly, then unclipped all points of the harness from the door, then unplugged the two plugs from under the dash and slid them through into the door. To do this you have to get that rubber sleeve between the two doors into the door. Just pry it off both ends (without tearing it) and then work it through the door. Then that white plastic piece that the rubber thing attached onto has to be pryed off and worked through into the door.
  3. Now all you have to do is take out the harness out of the other car and swap them, installing is the same as removal. Then put the manual window lift in the old and the moter/lift assembly into the new! Thats that! Oh yeah, don't forget the power window relay under the hood its in the box next to the battery.
It sounds to me like you can swap the ENTIRE door and just do step 1. to find the correct wiring harness to feed into the door.
:dsm:
I searched for "manual to power" "Power windows" "Power locks" "Door swap"... I guess I just fail at knowing how to search for things. Thanks for the reply.
I believe you searched and I'm glad I could help ya, sometimes that those search's can be a bit tricky to pull up the right stuff. You know a lot of times I refer to Google to pull stuff up on here since it seems to be a little more lenient when your trying to find something specific.
Hope that info helps though.
:dsm:
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
