Glliw
- 471
- 3
- Dec 18, 2005
Panama City Beach,
Florida
So I just put in the SBR g50 and I have some troubles from the install. The water pipe that had to be dented is now leaking. It is not leaking at the dent however. It leaks at the opposite end, where it bends around the block to the water pump. It this water pipe all one piece? What is the easiest way to fix this? It pours coolant out pretty quickly, not a steady stream, but a fast drip. Could swabbing a crapload of RTV sealant around there work?
Also, I'm having a preturbo exhaust leak. It looks to be at the manifold>engine area. I used all new gaskets for 02 housing, turbo to manifold and manifold to engine. The manifold to engine is a felpro. Is this just a crappy gasket?
Thanks,
Will
Thanks,
Will
