50 trim install/coolant blockoff
Glliw
471
3
Dec 18, 2005
Panama City Beach, Florida
So, I'm gonna be installing my brand spankin new SBR G50 this weekend. I've read thru the writeup here on DSMtuners on how to do, just making sure there wasn't anythign special I might need. It says to use a 14x1.5x10 bolt to block off the hole in the block for the coolant. Well, the smallest I can find is a 14x1.5x40. Where did you guys get your bolt, and is it possible that I could use a longer bolt?
fwdturbobov1996 said:
Cant you just tie them into each other??
thats how i did it -
I used around 1" of a break line (easy to get from any autoparts (they have metric)) and put a hose on it to connect to the other coolant line that needs to be blocked.
Exactly. Just loop the lines back to each other and you won't have a problem. If you need a picture I can always run out and take one.
Good luck with the install,
Andy
yeah why not just cut the bolt? that seems like an easy solution, I buy my fasteners from an industrial supply store aswell.. and when I get a certain size (m6, m8, ect) I always just get long ones cause I have to buy 50 at a time, then I just cut as needed, file it around the edges a bit and quickly chase the threads on the end.. always works fine.
