2G Possible Transfer Case Issue?
EvoSlapper
Aug 20, 2024
Philadelphia, Pennsylvania
Hello,
My 98 GSX had another issue pop up. A new clutch went in a few hundred miles before this happened. I was accelerating under boost when there was a loud bang and the car jolted. It then acted as if the clutch was slipping so I immediately thought an issue with the new clutch. As I was attempting to limp it home and jolted again, albeit not as violent as I wasn't heavy on the throttle, and the slipping went away. At this point I tested it a little more on my way home. Under heavy boost in 2nd gear it felt as if one of the rear tires was spinning. At this point I knew it wasn't the clutch. I got it home and observed the undercarriage and noticed driveline fluid all over the bottom of the t-case.
What should be my next step? I was thinking pulling the t-case as it's fairly simple to do then inspect the input shaft splines on the t-case and the output shaft splines on the trans. Any thing else I should be looking out for or taking apart? I appreciate any and all insight. Please let me know if any further info is needed from my end.
Output shaft and input coupler are my first guess. Hopefully not the center diff. A broken rear axle maybe another culprit.
