PORTFUELER help!
99 gs iowa
335
May 29, 2011
moravia, Iowa
ok ive been running the portfueler set up for a while and am wanting to take it to the next level. I am NOT wanting to go megasquirt! So what optioins/combinations should i go with is msd the way to go? or is there something else, also wanting the option to come with a 2step set up if optionable. THANKS!
No real cons, it will only be better then what you currently have. the only con I think of is complexity of your system. you wont find many write ups.
With PF, if you want to control timing, MSD or Crane are your typical choices. MSD I think has a better setup.
You need to pick up the split second AIC1-G4H with data acquisition then. It's the company that makes portfueler for HAHN. You can upload your current maps with the R4 program and never skip a beat, but with data acquisition you can overlap AFR and up to 3 other 0-5v Sources of data to really fine tune your maps. Also the MSD 6212 is a great choice; you can do everything your heart desires regarding ignition and boost. There are users who have entered the high 10's with these two products.
who besides HAHN has entered the high 10s on a PF setup? I thought most of the PF setups were in the mid 11s. At any rate, we did pick up the Data acquisition eic. The issue of heat soak and no compensation is still there with the PF though. I think he will make good power ( in the range he wants).
  • Wanted 6 bolt NT water pipe
    • chrisman287
