Popping noise at full boost..whats goin on?
Boostcreepgsx
Sep 12, 2004
carol stream, Illinois
i just completed the stage 1 setup with a small 16g, and a 255 pump, with the rest of the supporting mods. and @ 16psi, there is a popping sound, from the exhaust, as the rpm's go up, and after it shifts. (automatic) But it only seems like it does it after 2 or 3, 16psi pulls. Just out of curiosity, i plugged in my data logger, and my intake temp was at about 130. Could that have anything to do with it?
The intake temp is a little high but has nothing to do with your problem. First check your plugs and wires and replace them if they have alot of miles on them. Turing up the boost puts more pressure on the ignition system to fire so any weakness will show in the upper RPM band and under high boost. I would run the NGK cheap coppers (6 )Gap your plugs at .028
I would start there it sounds like you are misfireing under boost and is a common problem on engines that have stock original ignition.
Also check all of your intercooler pipe hose conections.
No worrys its just something simpe. ;)
Do a boost leak check. Go to www.vfaq.com to find out how to make a tester. If thats not the problem it would probably be ignition related. Change the plugs and wires. For plugs use NGK7's. They are the best.
