1G Pop-up Headlight mod?
Status
Not open for further replies.
What mod are you speaking of? The one where you can control the height at which they pop up, so you can have that lazy eye look? All you have to do is remove the interior panels below the glove box. You'll see a ton of wires back there. Pull them down and look for just a small little bundle of 2 or 3 wires (can't remember the exact amount). They have a connector at the end of them, and nothing coming out the other side of the connector. Kind of like a dead end I suppose. There is a small white insert thing in the end of that plug that you just need to remove. Once removed, you will be able to control your lights using the headlight/parking light knob, and the little pop up/down switch on the dash.
Look up CHICLET MOD , you'll find more about it and probably a better explanation then what I just gave you
Cool,thanks, I was looking for the small connector behind the passenger kick panel and i never found it. I will try looking behind the glove box panel. Thanks for the help. :talon:
the chicklet shoud be behind the kick panel. mine was taped to the back of a large wire loom, under a lot of black wire wrap. Keep looking, its in there!
:laser:
Ya the kick panel. Sorry I couldn't think of the word so I just said glove box. But ya I took out the kick panel, and there was a bunch of bundeled wires all taped together up there. I took off the tape and somewhere in that bundle was the connector. Then just used a tiny little flat head and got that chiclet whatever thing out!
Status
