Pop from pass. front?
Riceboy
55
Jan 25, 2004
LaPorte, Indiana
Ok. so i have a 1995 tsi fwd. all suspension is stock but i just replaced the whole half-shaft and after i replaced it everytime i get on it and hit boost i get a loud pop from it seems like right under the pass. floor board? but after it pops from accelerating it will pop again when i coming to a stop.
Thnx for any help
Terry
Check the torque on all your bolts.
Check your balljoint conditions.
I will Check tonight but also ive noticed that the upper ball joint squeks when i turn the tire and when the tire is on the ground and there is pressure on it but not when its jacked up in the air?could this relate to the problem at all
Could help to check all the ball joints in the front for rips or tears. Also, check the front axle boots for tears as well. Did you put enough grease in the roller bearings and axle ends?
Also, make sure to check the condition of the bolts on the carrier bearing (two bolts that attach the driver's side axle to the block). I had mine break off, and while it was a more regular thump-thump-thump (bearing hitting the oil pan) while driving, it's something worth checking while you're down there.
Check the inboard end of the compression arm. (That's where it mounts to the chassis.)
- Jtoby
ps. the compression arm is the long, curved, lower control arm
