quest49s
- 111
- 0
- Sep 22, 2002
Austin,
Texas
I've had this on my car for the past year or so, and thought i'd share it with everyone else, to help some folks out or to have people point out the flaws in it.
First off my 91 TSi AWD has:
Completely stock longblock
Exhaust:
TEC td05 18g ported
ported 1g o2
ported 2g exhaust manifold w/ 35mm deltagate mounted on collector
2.5"->3" rre downpipe
3"catback with testpipe
Intake:
3" intake w/ 2g maf
2.5" ic pipes about -- 6-7ft of pipe
Spearco core
cyclone IM
I bought an MSD Dis-2 around 3 years ago(before dsmlink was widely popular or for 1gs, and really the only other means of a stuuterbox where standalone) mainly for the stutterbox and increased power off the line. With the 2-step set at 5,500rpm i was able to build around 8 psi at the line which was great, but started thinking ways to build more boost. Then i remembered the base timing wire which you ground to set your base timing, this retards the engine timing to 5* ATDC.
So how does this come into play? Like most other people who have hooked up a MSD stutterbox they use the factory clutch safety switch and an aftermarket relay to engage the stutterbox while the clutch is pressed.
So what i did was hook the stutterbox wire and base timing wire to the aftermarket relay so when the clutch is pressed the stutterbox is engaged and the timing is retarded, with this combo at 5500 i am now able to build 16psi at the line due to the less controlled ignitions helping to spool the turbo.
Anyone seen anything like this on a dsm before? Questions comments, and concerns are welcome. Couple of my concerns are: The stress put on the exhaust/turbo from violent explosions, and repeat cycling of the ECU between Base timing mode and normal operation every time the clutch is pushed in.
If there is something you want more detail on or clarified let me know,
And one more thing i don't quite understand myself, if the MSD-DIS 2 studder boxs works by dropping spark in cylinders to keep the rpm at a set range wouldn't the fuel go thru the cylinders and ignite in the exhasut manifold regardless of timing adjustments? Or maybe the waste spark from the #2 cylinder is igniting the #3 cylinder fuel at the bottom of #3 stroke? Perhaps that little bit of timing retard allows the gas to escape and ignite on the manifold?
- Also not sure if the fuel is igniting on the manifold or while the exhaust vavles are open on the wasted sparks cylinder???
Anyway let me know what you think.
Jon
Exhaust:
TEC td05 18g ported
ported 1g o2
Intake:
3" intake w/ 2g maf
Spearco core
cyclone IM
Jon
