kaganader
- 161
- 3
- Feb 23, 2009
a planet,
New York
Hey guys,
Its been a while since I had a DSM and I found one that is modded quite right and doesn't look like he went the cheap way on anything. Body is in okay shape no dents just needs a really good buffer and detail.
It has a AEM ecu in it and the tune on it is a bit rich, he says when starting it up it would take a few cranks to start it because of that.
Now I remember on my last DSM I had E85 and I had to do that during the winter to get it going, but his is on pump gas 93. Could it be from being rich or should I steer away?
List of mods thats been done:
80,000 miles on chassis
rebuilt 6bolt engine swap with only 8,000 miles
ARP connecting rod bolts
ARP head studs
Hks 272 cams/ adjustable cam gears
AEM Sensors
Full 50trim turbo
Hks blow off valve
Turbonetics waste gate
AEM engine management system
external areomotive 1000 fuel system
Turbo smart dual boost controler
RC 550 fuel injectors
Brand knew ACT clutch kit
kyb adjustable shocks with eibac springs
I would change out the injectors to maybe 1050cc and run E85 in this since its all around me.
I'm going to go check it out tomorrow morning, just a bit iffy about having to crank it a couple of times for it to start.
Thanks Guys
ARP head studs
AEM Sensors
Full 50trim turbo
Hks blow off valve
Thanks Guys
