architechnik
- 690
- 11
- Jun 21, 2007
Glad,
Oregon
I have been working on updating/upgrading my entire a/f system from intake to fuel delivery. I have been using a pockerlogger (MMCd) for a few weeks to become comfortable with the stock readings before switching out the parts - I want to know when something looks/reads different.
I could use a few translations about the pocketlogger readings:
I have a few concerns about the fuel trims - The high, mid, and low read the same thing (96.8/98.4/94.5 respectively) no matter what the rpms, maf, or throttle read.
The TPS reads at around 9.7% at idle and the highest reading displayed is around 84% - even at WOT. I hardly ever recognize a change from the engine between around 65% and WOT. (And it actually spools faster at around 65% than WOT!) What could cause this?
My current upgrade/mod will involve an afc, fuel pump, fpr, and 2g maf/intake. I'm planning on getting a wideband 02 to tune everything in, but as I am reading the various posts, they seem to refer to different things.
I thought it was the sensor, but it appears to be an actual translator? Some sales places refer to just the gage as the wideband, but I'm pretty sure the stock sensor will not create the correct signal.
If I am using the pocket logger (MMcd, OBDI, or DSM Logger) what exactly do I need to get accurate readings (for the most effective use of $$)?
