Pocket Logger Help
I use their 2g setup. It does everything they advertise. The only issue I've had is getting the logs from my Palm to my laptop. I have not had any luck finding a serial-to-usb cable that will work with my computer, but I can transfer the data from one of the included programs via infrared ports.
Oh, and there is a glitch in TunerStein (one of the 2g programs include...the other is OBDGraph) that prevents file transfers to my computer. But I just view logs on the Palm and everything's cool. I don't know what comes in the 1g setup, so maybe you won't have this problem.
The cable from my car to Palm works flawlessly.
thanks alot for the quick reply and the help! this is the exact answer i was hoping for :thumb:
one more question, is this package all i need to data log on my 93?
http://www.obdloggers.com/mitsubishi.htm
I also got the 2G package, and yes you get everything you need, the software is already downloaded onto the palm, it also has info about how to set up a tune with the logger and how to use a AFC for the future. I also have not succesfully got the data onto my comp but its the port of my comp that is the problem not the palm.
The 1G kit is even better in that you can data knock.
good luck
