plugging the port on the turbine housing?
The orig line from the turbo connects to the BCS and wastegate. I assume your MBS is now connected to the port on the wastegate, and feeding off the BOV vacume line? Since you removed the BCS, where does the orig line off the turbo now connect to? :confused:
In my MBC install I took the VAC line that ran to the BOV cut and inserted a "T". The tee then ran to one side of the MBC, the other side of the MBC runs to the WG solunoid.
The vac nipple on the turbo is no longer needed and should be capped off. It originally fed the BCS and W/G, but since the BCS is no longer used and the W/G is now being fed a boost signal from the BOV line, it has no use and should be capped.
This is how it should ultimately look:
....................Tee
BOV =============Intake
...................MBC ====Wastegate
:dsm:
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
  • Wanted wtb black 2g dashboard
    Looking to buy a 2g black dashboard. Located in southern california but willing to travel.
    • randizzle420
