please some transmission advice
Status
Not open for further replies.
2gTalonnn
55
May 27, 2009
SD, NB, Canada
ok guys i really miss my car its hopeless its been down for about 2 months now. couldnt get it in gear clutch was done springs were broke. so bought that went through the hotline a bunch of times because of wrong clutches and defects. now got the clutch set in. now its the transmission the bolt hole by the firewall is STRIPPED. so i was trying to tap it then the tap fell IN that hole causing the shaft to stop turning which means it got wedged in there. so i took the bellhousing off about an inch when it would not move anymore so i saw these two bolts looking down in the bellhousing, tried to get them off one SNAPPED. can not find a transmission nor can i get the bellhousing off. i really want to get this thing running then SELL the pos. what do i do guys.....
Pictures are worth a thousand words! Try editing your post because its hard to understand what you are describing. Photos would be great. Try to cut out the unimportant details. That made my head hurt reading it :)
well im just stating all that has happened progressing in 2 months of my time and i want some logic towards it. i will have a picture of the transmission tommoro. anyways do you know why the bellhousing wont come off?
Not to be rude but Ive re-read your initial post several times and still cant figure out what you are talking about. :D
You have a ton of grammar mistakes and the way you are desribing the "bolt hole by the firewall" leads me to the assumption that the transmission might still be in the car? WTF
If you are trying to pull the bell housing with the motor and tranny in then STOP. Give yourself some elbow room and remove the transmission. If you cant get the bolts out yourself then haul it to a machine shop and have it done. At least then you wont tear more parts up.
ok ok i dont need an english lecture i did forget to mention that the transmission was out of the car sorry. what are you having trouble reading just read slow and use your pointer finger to follow the words haha jk. i guess my only question is how do you get the bellhousing off, or should i just go and buy a new tranny.
Read your first post and stop being a jackass. Im trying to help. But run-on sentences and no punctuation make it hard to follow.
When you said you can pry it out about and inch and it stops does it feel like its wedged or like something is holding it? It would be nice if you had some pics. If you have a bolt broken off that could be the issue. BUT I would definately take it to a machine shop before I purchased a new tranny.
ok you obviously cant help me, and you obviously cant take a joke either, im not a jackass, i told you i would put pics up tom, im sure your gonna repost some **** reply thats gonna try and outsmart me, go ahead i wont respond, make sure you go and visit englishteachertuners.com AND HOWS THAT FOR A RUN ON SENTENCE. bye
How about I give the English lecture...or just point you to the rules you agreed to? Post within the rules or feel free to not post at all.
Status
