Please Help W/ Bcs!!!!!!!!!!
One of the vacume lines that is attached to the BCS has a bubble in it where the restrictor is. Or if you don't want me to call it a vacume line, its on the 'tube' that's attached to the BCS.
Don't touch the pellet in the vacuum line if you remove it, the little port on the BSC won't be able to vent enough volume to actually reduce the pressure in the line leading to the wastegate actuator.
You pull the restrictor in the nipple of the BSC.
Steve
