2G Please help car keeps bogging out.
amballer82822
361
4
Jun 4, 2010
Pittsburgh, Pennsylvania
Hey guys cars been running great till this Morning was on highway and rpms dropped and car bogged out. The only exhaust leak I may have is where the cat converter should be because I removed it and replaced with straight pipe. But the rear o2 sensor is disabled from DSM link so idk? When I start the car it runs well, but when I give it gas the runs to much fuel and rpms drop and it cuts out.
I'd start with the maf make sure its connected, intake and or intercooler pipe are they aftermarket?
So it idles perfectly normal and will start up fine everytime? Then you press the pedal and it boggs down? In any pedal position?
It will start up and if you don't give it has it will bog out, you can gas it and it will run good but as soon as you set off the pedal it starts to bog out
Interloper pipe is not aftermarket but intake is
Just bought hard stock smic piping with a greddy flange, because my stock piping cracked, and I need to go buy two 10mm nuts for bov. And if bov wasn't on and I started the car it would bog out correct? Just asking because I hopped I solved the problem, well I guess I'll know as soon as I get the 10mm"s.
