Please Help!! - 2g spyder turbo stock ride height needed
hsk8te2006
182
Jun 9, 2007
Ann Arbor, Michigan
I just installed a new suspension yesterday, and in order to avoid having to get an alignment twice (opne now, and onec again when my new upper mounts come in), I want to keep the car at stock ride height for 2 weeks. The problem is, I forgot to measure what it was before I started.
I've tried searching for hours, and I can't find measurements for a basically stock 2g spyder anywhere!!!
I'm looking for the distance from the center of the wheel to the bottom of the center of the fender lip above each wheel.
Can anyone out there take 2 minutes and go measure their spyder's ride height on level ground and let me know?
Thanks so much!!!
Problem... your thread lists a front height of 15.75 inches, but another lists it at 14.50.
Also, knowing that the front and rear corners of a spyder have different weights from the hardtops (and not know for sure if they use the exact same spring rates or not), I figured it would be best to just ask someone who owns a spyder to take 2 minutes with a tape measure and find out for sure.
ANyone?
