Pistons
trixtert
48
Sep 26, 2004
Calgary,
Ive heard the stock Talon N/T Pistons can hold up too 7PSi if your compression is good. But If I was turboin my 94 Talon ES can I stay with these stock pistons for like 70,000km.
Ive also heard that the TSi Turbo (the 14b) can't have its boost turned down below 9PSi
the pistons should be fine on 7psi. you cant turn the 14b down past 11psi i believe. unless you rip apart the wastegate and changing the springs.
