spyderdrifter
- 5,434
- 864
- Jul 11, 2009
Somewhere in,
Colorado
I'm currently trying to install my pistons, but I can't get the ring spacer to lock together I guess. I know end to end, is way too big of a ring to fit the piston, but the ends won't mesh together. The links are the same size from end to end. What can I do?
Also, the ring packaging says install the middle and top rings with the arrows/ dots up. There's none of either. Only engravings for ring sizes. Other side is blank. Which side up?
. I've been getting into higher rpm and shifting around 4500-5000rpms. Normally I'd shift around 3500.
guess I'll be running the test again.
Please don't take my last reply to you as bad, wasn't trying to come off that way.
