2G Piston ring gap
agarcia892003
186
Feb 21, 2005
Green Bay, Wisconsin
Hello guys im building my 7 bolt and have a question about my ring gap.
Block is bored .020 over. I measured the gap on my rings and they are .013
Is this ok? I dont want to file the rings if i dont have to. Thanks in advance
Heat will be your biggest problem. Under boost, those slugs get hot and the rings right along with them. You didn't say what brand of pistons you are running, but here's what Wiseco says about it:
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
If I remember correctly, we set ours to around .022 on our 6-bolt stroker, built for big boost. We've been burned by too-small a ring gap, and it's not pretty.
Those gaps are way to tight. I go with .019/.021 for sub 600 and for over that .021/.023. Dont forget your second ring as both of you dont mention it.
You can use the stock clearances if you are doing a mild build but for high performance I would go with the specs recommended above.
Look in the FSM so see what it calls for if you're running stock cast pistons.
When i built my motor expecting to get 450-600awhp I gapped my rings to 0.21 so I recommend you to do about the same don't go under .017, also make sure to check your PTW.
Bore X .0055 +.003 = top ring gap
Top ring gap + .003-.008 =second ring gap
This is the factors that most ring manufactures have moved too.
I add the +.003 for a touch of padding incase there is a lean condition, or tune issue.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
