Piston ID on Stroker Pistons part# 21171 6571M86
Littlebeeper
310
Feb 15, 2004
Corpus Christi, Texas
This is wierd, supposedly this is a stroker motor (2.3), 4G63 withe the stroker crank, but i can't identify what pistons it has. all i see is these part numbers on the face 21171 6571M86 . i did a search and nothing came up. google search brought up nothing either (other than a kawasaki website) and the popular Weseco stroker pistons and others at Slowboy have completely different part numbers. any ideas?
i'm not concerned if its a stroker or not but i want to know if the pistons will hold up. i don't want trash pistons.
Sorry for the confusion but your wording was a little goofy. Where did you acquire a motor from that you are unsure if its stroker or not and dont know what components were used in its construction?
M86 would designate an 86mm diameter piston. 40 over
Just search for the beginning of the part number now.
no luck on that either. at least i know i can't machine the motor any more. that helps some. i'll keep looking and keep the ideas comming
