Pics of my DejonTool UICP, finally...
Spoolio
730
10
Sep 3, 2003
Port Charlotte, Florida
thanx, its fit really good, except for the upper part where it goes into the gm mas, its a really tight squeeze, seems to be off mark just a tad, cause when i put the pipe in, its not completey straight,
nice, i hate how they slap that dejon name on all their products now.. i wonder if you can request it without it.. luckily for me all my dejon parts I ordered way back when before they implented that.. which i will soon be getting rid of, so I guess mine is limited haha jk
I thought they started runnin the short route piping?? Unless your still rocking the stock smic.
I dig the half polished valve cover. Mine looks the same right now, haha. Actually yours is probably closer to done than mine. :)
haha, yeap, my valve cover is still in progress, i started to get fustrated and the wire wheel started hittin my wires and almost tearing them apart so i gave up till tomorow.
I had the same pipe and when I went front mount I cut the pipe near half way and used it for my upper short route IC pipe. Now I just use the elbow and the section that holds the MAF with a 2.5" straight piece of aluminum leading to the radiator dupport and my upper pipe from the FMIC. Adding the JM FAB SMIM allowed me to even shorten my upper pipe. Straight from the radiatopr support to the elbow/MAF! Save that pipe for when/if you go to a FMIC and want short route piping. I also am able to run a Cold Air Intake with my K&N sitting where the side mount once was and my holset has a 4" inlet pipe! Mark
Man, I wish I had a white talon... with my money I'll take what I can get, and red isnt so bad i guess. I bought the upper and lower dejon pipeing for mine, but i have the stock smic right now and I bought the stuff used, so it has the couplers for the dejon smic (a bit bigger). I need to get some step downs before I can install the pipes. Yours are shiny ;) Mine are red...
thats cool, they worked great for my setup, good luck with ## 1G, post some pics of it!
    • george bromwell
    • pma1123
    • Sdcryan1
