1G performance chip for 93 esi talon?
As far as I know from my research when i had a N/A, there are no "chips".
I've made real performance chips for 1G NT cars in the past but you need a NT EPROM ECU and your limited to doing things like changing the rev limiter and minor timing and AFR changes.
There is little in the way of performance gains to be cheaply had with a NT engine. You can't just turn the boost up. You have to change things like pistons, post heads, replace cams, run independent throttle bodies, get a replacement header, etc.
These things on eBay do little more than lie to the ECU about air temps, or barometric pressure in an attempt to trick the ECU into leaning the car out a little. They're mainly designed to separate fools from their money. Just like boost fluid, muffler bearings, electric turbochargers, etc.
