GSLENK
- 1,416
- 56
- May 25, 2011
DC,
Maryland
I just removed my pedal assembly, "unfortunately" the slack is not in the new looking assembly, Its in the MC rod. but I will be replacing all the bushings anyways with brass/bronze ones. (preventative for clutch install)
I have to adjust the rod all the way out to make the clutch engage at a high point and have no slack.
What does the welding do? I've seen some people do it on their own. It looks like the DIY jobs only keep the nut from coming loose. When shep does it, he welds the arm to the rod, and throws away the nut?
Also what materials are those? the assembly is obviously mild steel, the nuts and washers have a different color suggesting they are not the same material.
