clutch pedal bushings?
96eclipsegsx56
147
Mar 11, 2011
lowellville, Ohio
My dsm makes a clink noise after I push the clutch pedal in and put it into veer then release the pedal...my buddy suggested clutch pedal bushings?? If this sounds right where can I buy these bushings? And what are the instructions on removal and install?
There are a total of 3 bushings on the pedal...at least on my 99 and I'm thinking all of the 2Gs would be the same in that respect. There are 2 for the pedal pivot and 1 where the clutch master cylinder rod connects to the pedal. That is what I had to replace when I had the same symptoms that you are having. It's a simple push in bushing that get pressed into the the side of the pedal lever. You should also buy a new pin, because that might be worn too, depending on how long the bushing has been worn out. I got them from JNZ Tuning and I think that it was about $5.00 or so for the parts. It took me 5 minutes to replace.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
